I'm using Code Warrior 10.6 for FRDM - KL25Z board and im having some problem to perform division arithmetic
operation. No issue was found when build the project but when my division operation code was executed during debugging a
message “No source available for "__aeabi_idiv (0x000008C4)() "” was displayed.
Please help me to advice what should I do fix this issue, is this something to do with GCC and if yes, please advice what to do?
Thanks in advance.
Hi Kanagaraja.
I just create a new project and test division on my side. but i didn't see any problem. can you please test the project i attached.
can it also work for you?
if this doesn't address the issue, please upload your demo code here. I will test it on my side. thanks!
Zhang Jun
Hi Kanagaraja.
we can cast result2 to float in computation:
result3 = ((float)result2/(float)DENOMINATOR);
see my attached.
Zhang Jun
Hi Zhang Jun,
After i watch your video, i did exactly what you have done and found that i'm able to exercute the division code without any issue when i debug with Step Over(F6) and the mentioned problem only happened when debug with Step Into(F5). Can i know whether this is a normal issue seen when i debug a division code with Step Into(F5)? or something wrong with my CW configuration?
B.Kana.
