I add mydac driver in ...mqx\source\io, I use interrupt when the dac read point is in the buffer of top,
// isr code
void _mydac_int_isr(void * param_ptr)
void * event_ptr;
if (_event_open("event.global", &event_ptr) != MQX_OK) {
_event_set(cfg_data_ptr->event_ptr, 0x01);
void main_task
uint32_t initial_data
_mqx_int result;
/* Set up an event group */
if (_event_create("event.global") != MQX_OK) {
printf("\nMake event failed");
_task_block();
if (_event_open("event.global", &dac_buf_task_data.EVENT_PTR) != MQX_OK) {
printf("\nOpen event failed");
_task_block();
_mqx_int load_dac_buf_task_id = _task_create(0,
LOAD_DAC_BUF_TASK,
0);
if (load_dac_buf_task_id == MQX_NULL_TASK_ID) {
printf ("\n Could not create load_dac_buffer_task\n");
while(1)
_time_delay(1000);
//in my task
void load_dac_buffer_task(uint32_t param)
void * event_ptr;
_task_block();
while(1)
if (_event_wait_any(event_ptr, 0x01, 0) != MQX_OK){
printf("\nEvent Wait failed");
_task_block();
I debug ,the ISR _event_set successed, but the _event_wait_any is not responseed!why?
Please tell me How to do it, thanks!
Solved! Go to Solution.
Hello walle,
Please check the example attached,
Sol
Please check the below threads
K60 and MQX installed ISR not called, why?
Sol
Hi Sol .
thanks for your help, by the way , can you give me so demo that is ISR _event_set() a event ,and another task is _event_wait_any(). I try do it,but ,the task always wait.thanks agin!
walle.
Hello walle,
Sol
Hi Sol
thanks!
walle
