Freemaster forgetting max limit values for modifing variables.
martinmeier
Everytime I restart Freemaster, even if saving the project (pmpx format in the latest version 1.4.4.4, Build Jan 13 2015 11:14:29), the max value for some of my modifiable variables are set the same as the minimum:
That happens for both fractional and fixed point variables.
I've tried cloning and recreating the variables, with no success.
Is there a workaround for it?
Anyone else has this problem?
martinmeier
New information I found: it only happens when the xml ".pmpx" format is used. When I use the ".pmp" it doesn't happen. So it's half a solution.
