i.MX6SL BOOT_CFG2[7:6] setting
torus1000
Contributor V
i.MX6SL reference manual described different setting as attached.
Could anyone help me to clarify which one is correct?
Thanks.
Tags (3)
Yuri
  The i.MX6 SL EIM does not support 16-bit Non Multiplexed Address/Data Mode with
data bus located on high data bytes. Please look at Table 36 (EIM Internal Module Multiplexing)
of i.MX6 SL Datasheet.
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SLCEC.pdf
Yuri
Yuri
Yuri
