iMX6D gets over heated
madhurilokare
We are developing a SOM board using i.MX6D processor MCIMX6D6AVT10ADR and PMIC MMPF0100NPEPR2.
Whenever the board is powered on after some time the board gets over heated. I want to know what might be the problem?
Hi Madhuri
suggest to check Chapter 2,3,4,8 IMX6DQ6SDLHDG
and measure current on power rails. Probably some signal(s)
shorted to other or ground/power.
Also may be useful AN4509 i.MX 6Dual/6Quad Power Consumption Measurement
AN4579 i.MX 6 Series Thermal Management Guidelines
