does anybody have a dsp56805 config file for flash programmer v1.2?
danielmak
Does anybody have a DSP56805 config file for Flash Programmer v1.2?
TICS_Fiona
56800E Flash Programmer only works for 56800E, and it doesn't not support 56800 product.
To program DSP56F805, please use CodeWarrior, or flash_over_jtag.
CodeWarrior v8.3 can be downloaded from:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-56800E-DSC
It supports programming with USBTAP and Parallel.
flash_over_jtag is a command-line tool, however it does not support USBTAP. And it does not work on Windows 7.
I attached this tool.
Fiona Kuang
Technical Information & Commercial Support
ruvimelaver
Hello Fiona,
Thanks for your reply .
I tried to work with the "DCS Flasher" using the GUI ,but I am getting an error which I am not getting using CodeWarrior  .
Using the "DCS Flasher"  I Do a Program/Verify I get the following message :
Performing PROGRAM operation on MC56F84789 through the UTAP . . .
Error 1: Unaligned srecord at C:/work/Bootloader/uC/Bootloader/MC56F84789_Internal_PFlash_LDM/56F84789_Bootloader.elf.S:271: "S30B0001F3FDCDAB3412FF0046" .
But when I am using the Flash operation using the Codewarrior  I do not get any Error , please see the following :
Console output :
fl::target -lc "LC for Simple Flash"
fl::target -b 0x60400 0x1000
fl::target -v off -l off
cmdwin::fl::device -d "MC56F84789_P_FLASH" -o "144kx16x1" -a 0x0 0x6bfff
cmdwin::fl::image -f "C:\\work\\Bootloader\\uC\\Bootloader\\MC56F84789_Internal_PFlash_LDM\\56F84789_Bootloader.elf.S" -t "Auto Detect" -re on -r 0x0 0x6bfff -oe off
cmdwin::fl::erase image
Beginning Operation ...
Auto-detection is successful.
  File is of type Motorola S-Record Format.
Performing target initialization ...
Erasing ......
Erase Command Succeeded.
cmdwin::fl::write
Programming ...
Program Command Succeeded
Flash Operation. done
cmdwin::fl::device -d "MC56F84789_X_FLASH" -o "152kx16x1" -a 0x8000 0x3ffff
cmdwin::fl::image -f "C:\\work\\Bootloader\\uC\\Bootloader\\MC56F84789_Internal_PFlash_LDM\\56F84789_Bootloader.elf.S" -t "Auto Detect" -re on -r 0x8000 0x3ffff -oe off
Nothing to erase.  No sectors selected
cmdwin::fl::write
Flash Operation.  ...
Programming ...
Programming warning.  No data to be programmed in selected flash memory range.
cmdwin::fl::erase all
Erasing ..........
Erasing ..........
cmdwin::fl::blankcheck all
Flash Operation.
Blank Checking ..........
BlankCheck Command Succeeded.
Flash Operation.
Erasing ......
cmdwin::fl::write
Programming ...
cmdwin::fl::write
Programming ...
Please advise if you have a solution as I need to give our production line an easy tool for programming ( via command line ...batch ...)
Thanks again
Ruvi
ruvimelaver
Hello ,
Please advise if I can program the MC56F84789 using this tool as I did not see the .cfg file for the item.
Ruvi
TICS_Fiona
Hello Ruvi
56800E Flash Programmer does not support MC56F84789.
To program MC56F84789, user can use CodeWarrior for MCU10.6.4's built in flash programmer. CodeWarrior v10.6.4 can be downloaded from
http://tinyurl.com/6jo5tge
Or choose P&E's Cyclone MAX:
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=145
Or you can use DSC Flasher to program 56F84789. Please search 'AN4824' on NXP website (www.nxp.com) to download this tool and help document.  It is a free tool.
Best Regards
Fiona Kuang
TIC - Technical Information Center
TICS_Fiona
Fiona Kuang
