Hello Jimmy,
WLAN and BT radios utilize hardware coexistence signaling between the devices. We only have old version for this tool which is based on bluez and the old wifi driver. You need to contact the vendor to supply new version tool to support it.
Sergio
Hi Sergiosolis,
I made my module to run as wifi and bluetooth individually, but while running in coexistence mode, on boot bluetooth modules will get inserted and then if I start wifi it is not starting.
Do I need to enable anything in the Android BSP to run coex mode???
Please suggest me how to proceed further??
Platform : IMX6SL.
OS: Android kitkat 4.4.3
Thanks and Regards,
Mutyalarao.
