The license. dat
The license. dat
fredschoville
I downloaded the license. dat file and put it in the correct file location for CW 10.6, how ever when I open CW it tells me the product license has errors, when I hover over the error it says the license is for CW 10.5, any ideas on how to fix this.
TICS_Fiona
Where did you save the license file? Please place it under \MCU subfolder.
Are you logging on Windows as Administrator, and whether the system time was set on a past date?
If the above does not help, would you please click on <Help> menu-> Freescale Licenses, what is displaying in the sub-window? And select <Details> button on it to view the detailed information.
Please send me a screenshot to show this information.
I also need your license file. Thank you.
Fiona Kuang
Technical Information & Commercial Support
fredschoville
#CodeWarrior Development Suite - Basic Edition, Annual Subscription, Floating
#License - CodeWarrior for MCU Basic Edition (Windows - Eclipse) for Fred
#Schoville Software Account
SERVER this_host DISK_SERIAL_NUM=c43f51d2
VENDOR metrowks
USE_SERVER
INCREMENT BasicEditionMCU metrowks 10.50000 27-jan-2016 1 \
9B6136AF8DFD VENDOR_STRING="CodeWarrior for MCU Basic Edition \
(Windows - Eclipse)" ISSUER="Freescale Semiconductor" \
ISSUED=27-jan-2015 ck=84 SN="FSL - 12200941" TS_OK
fredschoville
VENDOR metrowks
USE_SERVER
trytohelp
Hi Fred,
this license file is a floating one.
It refers to the DLA-BASIC-FL_DEENUB5365 registration.
A floating license requires a PC defined as Server (to manage the License service through Flexlm) and other PC(s) defined as client(s).
Before to use it you must edit the license file and replace "this_host" by the server name.
The server and client can be the same PC.
For details to install and run a floating license, please have a look to the link:
      License Manager Installers|Freescale
the doc is in the page above - direct link:
      http://cache.freescale.com/files/soft_dev_tools/doc/brochure/FLTLICINSTWINBR.pdf
Pascal
Freescale Technical Support
fredschoville
fredschoville
VENDOR metrowks
USE_SERVER
trytohelp
How Can I help you ?
Pascal
Hi FRED,
While the License for 10.5 and 10.6 is the same .
You can attachment your error.
Alice
fredschoville
VENDOR metrowks
USE_SERVER
