We are Using MQX RTOS for our custom board based on MK60DN512ZLVQ10 series of Kinetis ARM Cortex-M MCUs. We have developed our application based on MQX 3.7 RTOS for our custom board and its working fine But we need to migrate from MQX3.7 to MQX 4.1.0.1. We have ported from MQX3.7 to MQX 4.1.0.1 and our application to MQX 4.1.0.1. But we are facing issue with _io_doprint function.
The printf function is working fine as we are able to see data over the serial terminal.
Is there any implementation difference between the function is version 3.7 and 4.1.0.1.
Can you please help us with the same?
Sonal.
Hi Sonal,
- Can you explain please what is the problem you have?
- printf works fine but _io_doprint dont?
- What is the exact error you are facing?
Carlos
