imx-lib with buildroot
Question asked by kim suhak on Jan 27, 2015
Latest reply on Feb 2, 2015 by jimmychan
Im working with i.MX6Q sabreauto
Im trying to compile  imx-lib 3.10.7-4.0.0 on buildroot version 2014.8.
my kernel version is 3.0.35.
I set kernel on buildroot as Linux kernel, local directory.
compiling kernel was no problem but, imx-lib didn't find kernel header files, I think.
the error logs are below
make[2]: Entering directory `/home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/build/imx-lib-3.0.35-4.0.0/ipu'
/home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/host/usr/bin/arm-none-linux-gnueabi-gcc -DIMX6Q -I/home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/build/linux-custom/drivers/mxc/security/rng/include -I/home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/build/linux-custom/drivers/mxc/security/sahara2/include -idirafter /home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/build/linux-custom/include/uapi -Wall -O2 -fPIC -c mxc_ipu_hl_lib_dummy.c -o mxc_ipu_hl_lib_dummy.o
In file included from mxc_ipu_hl_lib_dummy.c:41:0:
mxc_ipu_hl_lib.h:104:25: fatal error: linux/mxcfb.h: No such file or directory
#include <linux/mxcfb.h>
compilation terminated.
make[2]: *** [mxc_ipu_hl_lib_dummy.o] error 1
make[2]: Leaving directory `/home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/build/imx-lib-3.0.35-4.0.0/ipu'
make[1]: *** [ipu] error 2
make[1]: Leaving directory `/home/suhak/work/projects/achroI.MX6/bsp/buildroot-2014.08/output/build/imx-lib-3.0.35-4.0.0'
linux/mxcfb.h is in kernel/include/, but not found in buildroot.
do u have any idea??
