Freemaster with K20 72MHz
Question asked by abid esmail on Jan 26, 2015
Latest reply on Mar 19, 2015 by abid esmail
I setup freemaster via UART1 on a K20 72MHz processor and it's awesome. I followed the following tutorial:
http://mcuoneclipse.com/2013/08/24/tutorial-freemaster-visualization-and-run-time-debugging/
I would now like to try it with JTAG (since I use UART in my application). Is this possible? I currently get the following error when I select JTAG as the device in the FMSTR1 freeMaster component.
Error: This item is not supported by selected CPU.
Not sure if it is not supported or I need to enable some define somewhere. I do have JTAG on this CPU and am using it successfully.
