Is MPX4250 Series Pressure sensor (0 to 250 kPa, 0.2 to 4.9 V Output) available in a case size 482A-01?
The case size I need is same as MPXA4250AC6U:
However this series has a range of 20~250kPA. Looking for 0~250kPa.
Tom
Hi Thomas,
Unfortunately not, the MPX4250 series of differential or gauge pressure sensors is only available in a Unibody package as shown in the device data sheet.
If you have any other questions, please let me know.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
