[i.mx28] what is the best git repository to build kernel from
randalsteve
Hello
At the beginning - sorry for my probably dumb question. I want to build kernel for KaRo TX28 board(i.mx28) using buildroot. I want buildroot to get kernel code from git repository automatically but i have no idea what is the best repository to download the sources from. As i search my options are:
-the main kernel repository
-repository maintained by freescale: linux-2.6-imx.git - Freescale i.MX Linux Tree
-repository i found for Karo boards: git.kernelconcepts.de Git - karo-tx-linux.git/summary
I ask for advice - what the repository is most apropriate for me and why?
Thanks in advance
Labels (2)
Tags (3)
sinanakman
Senior Contributor III
I suggest you just stick to mainline kernel. Both of those
other trees you refer in your post seem to be outdated.
TX28 is already supported in mainline kernel :
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch/arm/boot/dts/imx28-tx28.dt...
I recommend to use the mainline kernel.
Hope this helps.
Sinan Akman
sinanakman
Hope this helps.
Sinan Akman
randalsteve
Thank You very much. Your response makes sense. I will follow Your advice.
Ragards
Mariusz
