CW6.0 for HCS08 and Help (F1) problem
BasePointer
I'm living crashing problem with the help system of CW 6.0. You can see this at attached gif file.
Did you live similar experience with it?
BP.
CrasyCat
Specialist III
Hello
This is working fine for me.
If you are able to reproduce the crash I would recommend you to submit a service request for that.
Click here to submit a service request.
make sure to provide reproducible steps, and attach information on the version of the tool you are using.
To retrieve that info:
  - Start CodeWarrior
  - Select Help -> About Freescale CodeWarrior
  - Click on "Install Products"
 - Click on Save as, save info to a file and attach it to the SR.
CrasyCat
CrasyCat
Specialist III
Hello
  - Start CodeWarrior
CrasyCat
