MPC885C Programmer
MPC885C Programmer
madhuvp
Hi All,
I have MPC885c based PCB , and just wanted to be programmed .Let me know is there any programmer other than CWH-UTP-PPCD-H
available
Madhu
alexander_yakov
We do not offer other debug probe for MPC8xx, but it may be available from third-party.
Also, please keep in mind, MPC885 device does not have programmable memory inside, so the memory you need to program is external - common NOR flash. If this memory is removable on your board, than you can use any NOR flash programmer.
