About GPU2D_CORE_CLK_ROOT frequency in i.MX6DQ vs i.MX6SDL.
Question asked by Keita Nagashima on Jan 21, 2015
Latest reply on Feb 9, 2015 by Keita Nagashima
Dear Sir or Madam,
My customer would like to change the device from i.MX6SDL to i.MX6DQ to increase performance.
But, we found the difference of GPU2D_CORE_CLK_ROOT frequency between i.MX6SDL and i.MX6DQ.
Refer to below spec about GPU2D_CORE_CLK_ROOT from Reference Manual.
i.MX6SDL --> (Default)528MHz (Max)533MHz
i.MX6DQ --> (Default)352MHz (Max)533MHz
My customer tried to set the increasing frequency, but the result of max frequency was 480MHz.
I confirmed the GPU2D_CORE_CLK_ROOT frequency in android jb4.2.2 on i.MX6Q SABRE.
The frequency was 480MHz, too.
(I confirmed the clock was 528MHz on i.MX6DL SABRE)
[Q1]
Is it possible to set the 528MHz freq of GPU2D_CORE_CLK_ROOT in i.MX6Quad?
[Q2]
And, my customer worried about the dropping the 2D performance compared with i.MX6SDL.
Do you have any compared performance data (i.MX6DQ vs i.MX6SDL)?
Keita
