KW01Z128_sniffer.srec
jasonchiang
     There is KW01Z128_sniffer.srec image file under Test tool 12/images/ folder of beekit. How to use this if I load this image into KW01 EVB ?
Is there any document for reference ?
mihaidragnea
Hi Tzyy-Hong,
You may find the information that you need in Chapter 5 (Protocol Analyzer, page 87) from the Test Tool User Guide (..\Freescale\Test Tool 12\Documentation\TTUG.pdf).
Basically, you need to download the sniffer image to your KW01 device, power cycle the the board after programming, connect the KW01 MRB to a laptop/PC using an USB cable, start the Protocol Analyzer, select the channel and start to capture the packets.
Please notice that the current KW01 sniffer image supports only Japan's bands. (920 MHz).
Mihai.
mihaidragnea
Hi Tzyy-Hong,
Mihai.
