Is a KSDK_1.1.0 based fsl_usb_device_cdc_class PEx component forthcoming?
jeffreygraves
(ie similar to fsl_usb_device_msd_class or fsl_usb_device_hid_class)
Tags (3)
marek_neuzil
The fsl_usb_device_cdc_class PEx component will be available in KSDK 1.3.0 release this year (Q3/2015).
Marek Neuzil
michaelsteffenf
Mark, Is this still on track to be released in Q3 using the KSDK1.3?
marek_neuzil
I have checked the current status and the fsl_usb_device_cdc_class PEx component support has been postponed. This PEx component will not be available in KSDK 1.3.0 release in September. But the Kinetis SDK USB CDC drivers are available, see for example documentation in KSDK_1.2.0\doc\usb\ folder (these USB CDC drivers can be used in any Kinetis project).
Marek Neuzil
michaelsteffenf
Marek,
Is there some documentation or guide on implementing our USB CDC Class driver into an existing KSDK PEx project.  I've got a customer using PEx for the entire project and he wants to use the PEx CDC component, but its not available, nor will be available in KSDK 2.0.  How can he implement the example USB CDC project into his PEx project?
Mike
marek_neuzil
Hi Michael,
I have asked Processor Expert development team to provide USB CDC support (example, user guide).
Marek Neuzil
F50SC
Hi Marek
As per Mike's last comment we have a similar project...can Freescale provide a step by step guide on how to implement USB CDC in a PEx + KSDK1.2 + MQX project.
Jerome
marek_neuzil
Marek Neuzil
