enabling timer compare through kernel
Question asked by Hamid Sani on Jan 20, 2015
Latest reply on Jan 21, 2015 by alejandrolozano
Hello community,
I have been trying to enable the timer output compare pin (MX6QDL_PAD_SD1_DAT2__GPT_COMPARE2) on the iMX6Q with no success. I haven't found any example that discusses how to properly do this. My understanding is that I need to enable the pin on the kernel and then I could set the OCR1, TCCR1, and TIMSK1 registers through Linux.
Here is what I have been doing:
edit the kernel/arch/arm/boot/dts/imx6q-udoo.dts (I have an UDOO board)
inset
&gptcomp {
  pinctrl-names = "default"
  pinctrl-0 = <&pinctrl_gptcomp>;
  status = "okay";
and in &iomuxc I added:
pinctrl_gptcomp: gptcompgrp{
  fsl,pins = <
  MX6QDL_PAD_SD1_DAT2__GPT_COMPARE2 0x1b0b1
Sadly this doesn't work correctly and building the kernel fails. I know that part of what I am doing is right because I have successfully enabled the UART3, 5 and I2C1 pins using similar method.
Any help would be appreciated.
