u-boot performace
Question asked by tang yongjun on Jan 20, 2015
Latest reply on Jan 21, 2015 by tang yongjun
u-boot booting time is very big with i.mx6solo than with i.mx53.  they do almost same thing: init system, read uImage from nand,and then bootm.   time of i.mx53 is 1 second, and time of imx6solo is 5 second. how can we speed up u-boot booting  with i.mx6solo?   below is booting log:
U-Boot 2009.08-svn110 (Jan 20 2015 - 12:45:01)
CPU: Freescale i.MX6 family TO1.1 at 984 MHz
Thermal sensor with ratio = 188
Temperature:   38 C, calibration data 0x5a850c69
mx6q pll1: 984MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 11000000Hz
Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [WDOG ]
Boot Device: NAND
DRAM:  512 MB
board.c 335 time:73
NAND:  Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit), page size: 2048, OOB size: 64
128 MiB
board.c 495 time:736
Hit any key to stop autoboot:  0
cmd_nand.c 235 time:749
NAND read: device 0 offset 0x3b00000, size 0x320000
3276800 bytes read: OK
cmd_nand.c 421 time:2859
cmd_bootm.c 580 time:2861
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35-2666-gbdde708-svn84
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3138564 Bytes =  3 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
cmd_bootm.c 693 time:4429
Starting kernel ...
U-Boot 2009.08 (Jan 19 2015 - 16:07:16)
CPU:   Freescale i.MX53 family 2.0V at 800 MHz
mx53 pll1: 800MHz
mx53 pll2: 400MHz
mx53 pll3: 216MHz
mx53 pll4: 455MHz
ipg clock     : 66666666Hz
ipg per clock : 33333333Hz
uart clock    : 21600000Hz
cspi clock    : 54000000Hz
ahb clock     : 133333333Hz
axi_a clock   : 400000000Hz
axi_b clock   : 200000000Hz
emi_slow clock: 133333333Hz
ddr clock     : 400000000Hz
esdhc1 clock  : 80000000Hz
esdhc2 clock  : 80000000Hz
esdhc3 clock  : 80000000Hz
esdhc4 clock  : 80000000Hz
nfc clock     : 26666666Hz
Board: MX53-LOCO 1.0
Boot Reason: [POR]
Boot Device: NAND
I2C:   ready
DRAM:  512 MB
board.c 364 time:60
NAND:  Manufacturer      : Hynix (0xad)
Device Code       : 0xf1
Cell Technology   : SLC
Chip Size         : 128 MiB
Pages per Block   : 64
Page Geometry     : 2048+64
ECC Strength      : 4 bits
ECC Size          : 512 B
Data Setup Time   : 45 ns
Data Hold Time    : 30 ns
Address Setup Time: 25 ns
GPMI Sample Delay : 6 ns
tREA              : Unknown
tRLOH             : Unknown
tRHOH             : Unknown
Description       : <None>
128 MiB
board.c 522 time:182
cmd_nand.c 235 time:192
NAND read: device 0 offset 0x3b00000, size 0x280000
2621440 bytes read: OK
cmd_nand.c 421 time:721
cmd_bootm.c 573 time:724
## Booting kernel from Legacy Image at 70800000 ...
   Image Name:   Linux-2.6.35.3-744-g27fdf7b
   Data Size:    2431424 Bytes =  2.3 MB
   Load Address: 70008000
   Entry Point:  70008000
OK
cmd_bootm.c 675 time:808
Starting kernel ...
