what should I modify for change emmc from 8g to 16g?
mingmingyuan
Rita_Wang
By the way, which board and BSP are you using?
Dan
mingmingyuan
first, thank you for your help!
we hardware engineer draw Schematic according to imx6q sd board.  I think I should change partition tabel ( for example data partition )for emmc chage from 8g to 16g,can you tell how to change partition table ?
Rita_Wang
Hi mingming yuan,
Which version of BSP are you using?
Have a great day
Dan
mingmingyuan
dear sir:
we hardware engineer draw Schematic according to imx6q sd board. we run Android 4.4 system  \
Rita_Wang
You have to modify nothing when you change emmc from 8g to 16g. The 16g operation mode is the same to 8g.
Hope this can help you.
Have a great day
Dan
