Hi all,
Apologies if this thread already exists somewhere. I'm working on a project and I'm in the process of tightening the screws a bit. I've been looking at the routines in kernel/klog.c, and a few routines to get information related to stack usage. Is there a way to get an actual stack trace? Minimally, I'm interested in being able to get a stack trace (with args) of a failed task at the time of failure and dump it out to persistent storage for later retrieval. Any advice would be *greatly* appreciated.
Thanks in advance,
Rob
Hello Rob,
Please check the attached document and let me know if this helps,
Sol
Hey Sol,
Thanks for getting back to me. Sorry if I'm being a bit dense, but where is the attached document? :smileyhappy:
Best,
Rob
The document is attached to my replay, in addition you can find this doc at the path: C:\Freescale\Freescale_MQX_4_1\doc\tools\cw (MQX_PerfTool_Getting_Started)
Sol
Unfortunately, I don't think that's going to do it. I'm looking for a way of programatically determining the stack trace without having to use a debugger.
Please check the below thread and let me know if this helps!!
MQX Tools best way to post mortem dying task?
Sol
