Is it possible to eliminate the effect of tilt angle while using the MMA7361?  I am seeking an analog acceleration value that remains predictable under variable sensor orientation.
Question asked by Matt Connolly on Jan 14, 2015
Latest reply on Jan 20, 2015 by Joshevelle
The MMA7361 appears to act as a inclinometer while at a standstill.  My application will have unpredictable angles of tilt applied to the sensor.  This then affects the analog output because the MMA7361 incorporates both the acceleration value and the "tilt" value in it's final output.  Anyone have a suggestion that might kick-start a solution?
