Thank you for your answers.
I knew only the M52235EVB with the PowerOverEthernet & H2019, which is a bit complex. So i was looking for an easier solution. It looks like the H1102 is a good alternative for me.
Regarding the "firmware uploading", i think i should better make a separate post, considering the PHY protection issue is fixed.
Regards.
