Hi there,
you are probably using an early version of the tools, FYI I'm using build 70612 and the problem you are describing cannot be reproduced.
In order to get access to the latest beta drop of CW 8.8 I would suggest to touch base with a FSL sale representative and request an early access to the beta drops.
Hope this helps...
best regards
