which interrupt I have to enable in CPU to get interrupt on input capture mode .
Refer to
https://community.freescale.com/thread/338349
Pascal
Freescale Technical Support
Hi KDN,
I suggest you use Capture component and refer demo code under
C:\Freescale\CWS12V5_1\ProcessorExpert\Projects\Test projects\Capture
Zhang Jun
this answer is for you. if it helps, please click on "Correct Answer " button. Thanks!
