Unable to use NAND Flash in TWR-K60F120M with TWR-MEM module using MXQ 4.1
Question asked by Maciej Wdowiarz-Bilski on Jan 8, 2015
Latest reply on Jan 27, 2015 by Daniel Chen
I have tower setup with TWR-K60F120M and TWR-MEM boards and I'm trying to run demo.c program from mfs_nandflash_twrk60f120m. After opening file system with fsopen, I've got response:
shell> fsopen
Unable to open nandflash device.
You must run "nandrepair" command
shell> nandrepair
Repairing...
Error opening filesystem: UNKNOWN ERROR !!!
For MQX 3.8.0 I've found in Release Notes (http://cache.freescale.com/files/soft_dev_tools/doc/support_info/FSL_MQX_TWRK60F120M_RELEASE_NOTES.pdf) information that:
- When using Nand Flash module , remove MEM board from the tower due to the hardware conflict between Nandflash Module and FlexBus Module
Besides, I've also found information about disconnecting FlexBus (https://community.freescale.com/thread/309185) by disconnectingJ11 and J16 jumpers. Unfortunatelly it didn't help.
Important note is that alone TWR-K60F120M module works fine.
Do you have any idea what could be done ?
Thank you,
