I have a question. I use the Qt5.3.2 the arm environment is imxSABRE6Q .the GStreamer version is 1.0 src:imxv4l2src sink:imxeglvivsink .
1. when start camera, the screen only a frame .
2. then I trigger event that the camera stop. Then I again trigger one event ,the camera start working is OK, but after about 30s the screen display video stop .
I need some suggestion about it.
Wang
Can you please check your camera interface with mxc v4l2 test?
Saurabh
