KDS 2.0 and KSDK 1.1 KDSK+MQX
w2vy
Contributor V
I am slowly coming up to speed with KDS/KSDK...
My ultimate goal is move a project I was working on maybe 2yrs ago with CW10 and MQX into KDS/KSDK.
I started looking at some of the demos (like web server) but they seem to need MQX installed
After a bunch of digging and edits to this post...
I discovered if I create a KDS project that selects "Kinetis SDK" and "Processor Expert"
I can look at the OS component "osa1:fsl_os_abstraction" and set the OS to MQX_KSDK
I then get a range of Lightweight APIs (maybe recently known as mqx_lite?)
The SDK then gives support to all the devices on the chips.
While I do try doing a Hello World app, I wonder what else I might need to do basic socket communications.
the "fsl_enet" Component has a range of APIs, but I doubt that TCP/IP is included...
Do I need a Full MQX release to get the TCP/IP stack?
Ironically as I write this I realize that my first project can survive on just UDP, but my current code is written to use sockets.
A stack is still the best way to go for sockets...
Tom
Tags (4)
ivadorazinova
Tom Moulton,
if you will be interested in lwIP TCPIP Stack, you can look at the documentation on
C:\Freescale\KSDK_1.1.0\doc file lwIP TCPIP Stack and Kinetis SDK Integration User’'s Guide.pdf
chapter 5.4 Step-by-step guide for the Kinetis Design Studio IDE
I hope it helps,
Iva
ivadorazinova
Hi Tom Moulton,
for TCP/IP you can use the MQX RTOS for Kinetis SDK. It is called RTCS and it is for Ethernet Communication.
If you installed the package, here you have some examples C:\Freescale\KSDK_1.1.0\tcpip\rtcs\examples
And I include the MQX Software Comparison from our pages Freescale MQX™ Software Solutions|Freescale
Which package you need according to your chip
Iva
danielchen
My understanding is: RTCS (Real-time Communication Sute) is not supported in MQX Lite.
