Referring to the i.MX6 SABRE-SDB and –SDP reference designs, Freescale is providing these files in OrCAD Capture version 16.3 or later. This is not compatible with earlier versions of OrCAD or any of the conversion utilities provided by Altium.
I'm looking for a version to support Altium versions 9, 10 and 13, and/or OrCAD version 16.0.
DSN files are attached if someone within the community wanted to convert, that would be appreciated.
Thanks in advance.
Scott
Original Attachment has been moved to: SPF-27516_C4.zip
Solved! Go to Solution.
Please try the enclosed file in OrCad 16.2 format.
Yuri
