I want to cross compile QT applications on my PC for IMX6 Solo based Nitrogen 6X board.
My host PC which is Ubuntu 12.04 with QT creator.
Board has Ubuntu 14.04 running on it.
I tried to set cross compiler in QT creator but in did not work ? ?
Raspberrry pie steps dont work for IMX6...
i installed QT creator on board but it does compile or run projects.
Can some one please post links and steps that how can i make an QT app on my PC and Run on Board.
Hi carlos Casillas ,
i am new to linux and programming
I cannot build qmake for board on my host that's main problem......:smileyplain:
i followed this link Building QT for i.MX6
the error is same as maxavadallat has posted in above post other specs are as above.....
please see if u can help.
I dont have particular recommendations.
we have interfaced a sensor with boards UART and C++ code is gathering data from the sensor.
the board runs Boundry Devices Ubuntu Trusty December 2014 release image with file system.
i need to build an Qt app on top of it which can 1.)display my sensor data 2.) allow me to access specific hardaware GPIO's and UART
Deactivated user, Boundary Devices, do you have some recommendations for this case?
