Hi, I'm using CodeWarrior PA professional edition V8.8 for developing MPC8309 application. After install MQX 3.8, I cannot install extensions (under tool subdirectory) manually into CodeWarrior directory, Could you give me some advice?
Thank you.
Hello Ryan
There exists a patch for MQX. It is on the DVD that comes with the board: TWR_MPC8309_FSL_MQX_BSP.zip
It is created by Embedded Access, so for any questions about mqx 3.8.1 or 4.0 or support question related to it should be sent to support@embedded-access.com, as stated in the FSL_MQX_MPC830X_release_notes.pdf in the package.
Sol
