iMX28 :  NC pin on Ball Map register setting
Question asked by koichi sakagami on Dec 26, 2014
Latest reply on Dec 27, 2014 by igorpadykov
Dear community,
I am checking the Reference Manual (MCIMX28RM) for register setting
and Data Sheet for Ball Map in order to make a software initial routine.
The i.MX280 has the NC pins more than other i.MX28x series.
  1. Are the register settings defined as the NC pin at The i.MX280 in resetting
      same as the the Reference Manual depiction?
  2. Is it no problem to keep using in the resetting register value for NC pin register setting ?
  3. If I will modify the NC pin register setting,  does it have any influence on the i.MX280 ?
Koichi Sakagami
