KL46Z - Burned MCU
KL46Z - Burned MCU
igorlalik
I want to know why, when I charge KL46Z by battery 7,2V into pin P5-9V which has a stabilizator, my MCU burned !!?
Jorge_Gonzalez
Hello Igor:
What pin P5-9V are you referring to? Is this the J3[16] pin in the FRDM-KL46Z?
Regards!,
Jorge Gonzalez
igorlalik
Hello Jorge!
Thanks for answer! Exactly, i used J3[16] pin to connect battery and on green board also was connected servo and 2 motors. I used it in that combination for 2 days and today i heard quik click and smell of burning element. I thought that was MCU, because it was very hot. Now when i charge board by USB, only MCU is getting hot and i can't flash program into board, because of error: No Debug Unit Device found. I don't know if that MCU is burned or something else. If you know what it might be please help :smileyhappy:
Regards!
Jorge_Gonzalez
Hello Igor:
You are right, sorry, my previous comment was misleading. U1 should indeed regulate the P5-9V input.
Your picture does not show the problem. It is strange that it was working for 2 days and suddenly crashed.
I am not familiar with the Freescale Cup board or the hardware connections, you may post your issue to the University Programs space.
Regards!
Jorge Gonzalez
