Hi team,
my customer Larimart would like an easy HW question about the as and type connection more correct on the MCF5475 to implement, in order to FlexBus not multiplexed mode.
In fact in the user Manual at the section 2.2.6.3 is described as to use the port FlexBus AD and PCIAD in not multiplexed mode, but only described.
Now my customer would like be sure the right connections by flash/SRAM/FPGAs.
Exist an Application note , or raccomandations for connections by these devices... if exist a schematic will be fantastic. ?
thank a lot
Pierluigi
