About accuracy of TWR-KM34Z50's 24bit SDADC
romehuang
Hi I'm evaluating TWR-KM34Z50's 24bit SDADC, I wired both EXT_SD_ADP0 and EXT_SD_ADM0 to VSSA, and run afe_test, then I got values between 0x6df8 and 0x824a, it seems 13 bit shifting. Anything wrong in my configuration or is it normal?
Rome.
apanecatl
Senior Contributor II
Hi Rome, can you share your code to check it out?
