K70 150, increase clock from 120MHz to 150MHz
Question asked by arnogir on Dec 15, 2014
Latest reply on Mar 3, 2017 by arnogir
Hello
U used a K70 120m with tower K70 system and MQX 4.1.
I migrate to a home board with a K70150m, then  I would modify MQX to increase CPU clock from 120MHz to 150MHz.
I made following modifications (See Tag "//debug AG Clock"):
static void Cpu_SetMCGModePEE(uint8_t CLKMode)
 switch (CLKMode) {
 case 0U:
 /* Switch to PEE Mode */
 /* OSC0_CR: ERCLKEN=1,??=0,EREFSTEN=0,??=0,SC2P=0,SC4P=0,SC8P=0,SC16P=0 */
 OSC0_CR = (uint8_t)0x80U;
 /* MCG_C10: LOCRE2=0,??=0,RANGE1=2,HGO1=1,EREFS1=1,??=0,??=0 */
 MCG_C10 = (uint8_t)0x2CU;
 /* OSC1_CR: ERCLKEN=1,??=0,EREFSTEN=0,??=0,SC2P=0,SC4P=0,SC8P=0,SC16P=0 */
 OSC1_CR = (uint8_t)0x80U;
 /* MCG_C1: CLKS=0,FRDIV=5,IREFS=0,IRCLKEN=0,IREFSTEN=0 */
 MCG_C1 = (uint8_t)0x28U;
 /* MCG_C2: LOCRE0=0,??=0,RANGE0=2,HGO0=0,EREFS0=0,LP=0,IRCS=1 */
 MCG_C2 = (uint8_t)0x21U;
 /* MCG_C11: PLLREFSEL1=0,PLLCLKEN1=0,PLLSTEN1=0,PLLCS=0,??=0,PRDIV1=3 */
 MCG_C11 = (uint8_t)0x03U;
 /* MCG_C11: PLLCLKEN1=1 */
 MCG_C11 |= (uint8_t)0x40U;  /* Enable the PLL */
 /* MCG_C12: LOLIE1=0,??=0,CME2=0,VDIV1=8 */
 MCG_C12 = (uint8_t)0x08U;
 /* MCG_C5: PLLREFSEL0=0,PLLCLKEN0=0,PLLSTEN0=0,??=0,??=0,PRDIV0=4 */
 MCG_C5 = (uint8_t)0x04U;
 /* MCG_C6: LOLIE0=0,PLLS=1,CME0=0,VDIV0=8 */
 //Debug AG Clock MCG_C6 = (uint8_t)0x48U;
 MCG_C6 = (uint8_t)0x4EU;
 while((MCG_S & 0x0CU) != 0x0CU) { /* Wait until output of the PLL is selected */
 break;
 default:
 break;
And then
//debug AG Clock #define CPU_BUS_CLK_HZ 60000000U /* Initial value of the bus clock frequency in Hz */
 //debug AG Clock #define CPU_CORE_CLK_HZ 120000000U /* Initial value of the core/system clock frequency in Hz. */
 #define CPU_BUS_CLK_HZ  75000000U /* Initial value of the bus clock frequency in Hz */
 #define CPU_CORE_CLK_HZ  150000000U /* Initial value of the core/system clock frequency in Hz. */
 #define CPU_CLOCK_CONFIG_NUMBER  0x03U /* Specifies number of defined sclock configurations. */
 //debug AG Clock #define CPU_BUS_CLK_HZ_CLOCK_CONFIG0 60000000U /* Value of the bus clock frequency in the clock configuration 0 in Hz. */
 //debug AG Clock #define CPU_CORE_CLK_HZ_CLOCK_CONFIG0 120000000U /* Value of the core/system clock frequency in the clock configuration 0 in Hz. */
 #define CPU_BUS_CLK_HZ_CLOCK_CONFIG0  75000000U /* Value of the bus clock frequency in the clock configuration 0 in Hz. */
 #define CPU_CORE_CLK_HZ_CLOCK_CONFIG0  150000000U /* Value of the core/system clock frequency in the clock configuration 0 in Hz. */
/* CPU frequencies in clock configuration 0 */
 //debug AG Clock #define CPU_CLOCK_CONFIG_0 0x00U /* Clock configuration 0 identifier */
 //debug AG Clock #define CPU_CORE_CLK_HZ_CONFIG_0 120000000UL /* Core clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_BUS_CLK_HZ_CONFIG_0 60000000UL /* Bus clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_FLEXBUS_CLK_HZ_CONFIG_0 40000000UL /* Flexbus clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_FLASH_CLK_HZ_CONFIG_0 20000000UL /* FLASH clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_USB_CLK_HZ_CONFIG_0 0UL /* USB clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_PLL_FLL_CLK_HZ_CONFIG_0 120000000UL /* PLL/FLL clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_MCGIR_CLK_HZ_CONFIG_0 0UL /* MCG internal reference clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_OSCER_CLK_HZ_CONFIG_0 50000000UL /* System OSC external reference clock frequency in clock configuration 0 */
 //debug AG Clock #define CPU_ERCLK32K_CLK_HZ_CONFIG_0 32768UL /* External reference clock 32k frequency in clock configuration 0 */
 //debug AG Clock #define CPU_MCGFF_CLK_HZ_CONFIG_0 24414UL /* MCG fixed frequency clock */
 #define CPU_CORE_CLK_HZ_CONFIG_0  150000000UL /* Core clock frequency in clock configuration 0 */
 #define CPU_BUS_CLK_HZ_CONFIG_0  75000000UL /* Bus clock frequency in clock configuration 0 */
 #define CPU_FLEXBUS_CLK_HZ_CONFIG_0  50000000UL /* Flexbus clock frequency in clock configuration 0 */
 #define CPU_FLASH_CLK_HZ_CONFIG_0  25000000UL /* FLASH clock frequency in clock configuration 0 */
 #define CPU_PLL_FLL_CLK_HZ_CONFIG_0  150000000UL /* PLL/FLL clock frequency in clock configuration 0 */
But after try, CPU clock is always 120MHz. (LCDC clock with a div 4 is always at 30MHz...)
what I have forget to upgrade clock frequency?
