MKE06Z64 connection error
Question asked by Kenji Yoshida on Dec 13, 2014
Latest reply on Aug 6, 2017 by CARLOS PICHARDO
Hello
I made a target board for MKE06Z64VLD4.
First,  I set new empty project by CW10.6.  And  I pushed  debug button. But It appear loading error ARP......
I try to drive power 3.3V.  In this case, Target Connect is success from MultiLink universal.
But  Taget is not success 5V power.   I sure did install CW10.6 update 2.0.0 and updated Multilink debugger of P&E micro.
following connection message 3.3V and 5.0V
// -----------------------------------------------------3.3V----------------------------------------------------------------------------------------------------
Executing Initialization File: C:\Users\workspace\test3/Project_Settings/Debugger/init_kinetis.tcl
radix x
cmdwin::eclipse::config hexprefix 0x
cmdwin::eclipse::config MemIdentifier p
cmdwin::eclipse::config MemWidth 32
cmdwin::eclipse::config MemAccess 32
thread break: Stopped, 0x0, 0x0, cpuARMLittle, test3.elf (state, tid, pid, cpu, target)
cmdwin::eclipse::config MemSwap off
cmdwin::reg User\/System Mode Registers/LR = 0xFFFFFFFF
cmdwin::reg Breakpoint Unit Registers/BP_COMP0 = 0x0
cmdwin::reg Breakpoint Unit Registers/BP_COMP1 = 0x0
cmdwin::reg Core Debug Registers/DEMCR = 0x1000001
cmdwin::reg Data Watchpoint and Trace Unit Registers/DWT_FUNCTION0 = 0x0
cmdwin::reg Data Watchpoint and Trace Unit Registers/DWT_FUNCTION1 = 0x0
cmdwin::reg Watchdog timer (WDOG)/WDOG_TOVALH = 0x03
cmdwin::reg Watchdog timer (WDOG)/WDOG_TOVALL = 0xE8
cmdwin::reg Watchdog timer (WDOG)/WDOG_CS2 = 0x03
cmdwin::reg Watchdog timer (WDOG)/WDOG_CS1 = 0x23
Starting 3rd party flash programming...
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : SPECIFY_NETWORKCARD_ENABLED, Value : 0, R) => DI_ERR_NONFATAL
INF: Copyright 2012 P&E Microcomputer Systems,Inc.
INF: Command Line :"C:\Freescale\CW MCU v10.6\eclipse\..\MCU\bin\de.exe" -noni -language en -ORBendPoint giop:tcp:127.0.0.1: -ORBtraceLevel 0
INF: CMD>RE
INF: Initializing.
INF: Target has been RESET and is active.
INF: CMD>CM C:\Freescale\CW MCU v10.6\MCU\bin\Plugins\support\arm\gdi\P&E\ke06z64m4_pflash_pipeline.arp
INF: Initializing.
INF: Initialized.
INF: ;version 1.02, 02/07/2014, Copyright P&E Microcomputer Systems, www.pemicro.com [ke_64k_pflash_ftmre_m0]
INF: ;device freescale, ke06z64m4, desc=pflash_pipeline
INF: ;begin_cs device=$00000000, length=$00010000, ram=$20000000
INF: Loading programming algorithm ...
INF: Done.
INF: CMD>EM
INF: Erasing.
INF: Module has been erased.
INF: Initializing.
INF: Initialized.
INF: Done.
INF: CMD>PM
INF: Programming.
INF: Processing Object File Data ...
INF: .
INF: Programmed.
INF: CMD>VC
INF: Verifying object file CRC-16 to device ranges ...
INF:    block 00000000-000000BF ...
INF: Ok.
INF:    block 00000400-00000AFB ...
INF: Ok.
INF:    Checksum Verification Successful. (Cumulative CRC-16=$6A7D)
INF: CMD>RE
INF: Initializing.
Executing download task: C:\Users\workspace\test3/Project_Settings/Debugger/init_kinetis.tcl
radix x
// -----------------------------------------------------5.0V----------------------------------------------------------------------------------------------------
radix x
INF: CMD>RE
INF: Initializing.
INF: Initializing.
INF: Initialized.
INF: Done.
INF: CMD>EM
INF: Erasing.
INF: Initializing.
INF: Initialized.
INF: Done.
INF: CMD>PM
INF: Programming.
INF: .
INF: Programmed.
INF: CMD>VC
INF: Ok.
INF: Ok.
INF: CMD>RE
INF: Initializing.
radix x
radix x
INF: CMD>RE
INF: Initializing.
INF: Initializing.
INF: Error loading .ARP file : C:\Freescale\CW MCU v10.6\MCU\bin\Plugins\support\arm\gdi\P&E\ke06z64m4_pflash_pipeline.arp. Set PC and Run Error.
ERR: Error loading programming algorithm - load aborted.
ERR: Error occured during Flash programming.
Please follow about this.
