Config MC33908
Config MC33908
pabloprieto
Hi Guys,
I'm trying to config the safety mode of the MC33908 SBC, throught an MPC5643L. I have a lot of problems with the Watchdog and the initialization of the safety mode.
Has anybody worked with this chip, or have you any initialization example, that I can use as a template?
I can achive the normal mode, but I get several WD errors, so I think that I am not doing the right thing.
Thanks a lot in advance
Pablo
TomasVaverka
Hi Pablo,
Sorry for the delay in answering your question.
The example project (KITMPC5643DBEVM Demo Code) available for the KITMPC5643DBEVM might be a good reference for you.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
ricardosoares
I am facing problems with the MC33907.
I can perfectly work in debug mode, I can successfully refresh the watchdog, everything is fine. However, when I exit the debug mode putting a pull down in the debug pin and do a power on reset. The supply starts putting the reset low during aprox. 8 seconds and then everything is shut down. What am I doing wrong?
