FRDM boards parts placements measurements
Question asked by Roland Resurreccion on Dec 9, 2014
Latest reply on Dec 10, 2014 by Roland Resurreccion
hi,
     i would like to ask if anyone has the measurements or eagle file of FRDM boards. i'm planning to put my custom board on top of it and using the header pins. i know that its compatible with arduino shields and you can the baord layout for it. i'm looking for the location of the 5V supply pin which is located close to the push button switches on the FRDM-K22F. my custom board will powering the FRDM board so i need this pin to act as an external supply im not going to use the USB for power on this project.
thank you
Roland
