Hi, I found the example in the KSDK/USB floder (dev_msd_disk_frdmk64f120m_bm) that is compiling and working as expected if I select the Ram Disk.
But if I select the SD Card there is acompile error: it can't find the sd.h file.
How can I make it working?
Thank Regards Giacomo
Ciao Giacomo,
That function is not enabled in the actual version of SDK (1.0.0), it will be enabled in the next release 1.1 that anyway will be public on December 16th so stay tuned :smileywink:.
Cheers,
Antonio
Ahh ok thanks, at least I have a ETA for next KSDK release.
Regards Giacomo
