MCF5271 Debugging Problems in CodeWarrior 10.6
Question asked by Keith Fowler on Dec 5, 2014
Latest reply on Jan 9, 2015 by Carlos_Mendoza
I've recently switched to cw10.6 and am experiencing problems debugging my projects using the PE Micro Cyclone Max.
The project and debug configurations were imported from a previous stable 10.2 build, and compiles just fine in 10.6.
However, now when I launch a debug session the code is slow to download to the target and I receive the following warning:
Starting 3rd party flash programming...
ERR: Warning: Programming algorithm not found for this device.
Once the code eventually loads, I get a further warning regarding breakpoints:
"Unable to set all the breakpoints requested. Some breakpoints may be disabled and will not stop the processor"
I only have two breakpoints defined, and just one active. I believe the MCF5271 uses software breakpoints, so I should be unlimited.
In addition, I often loose my debug context and control of the target while debugging.
I noticed that the Cyclone Max firmware was updated from 7.80 to 7.84 when I 1st ran a CW10.6 debug session.
Are there any recommendations to fix these debug problems in CW10.6?
