MK64FN1M0VLL12 reset problem after power failure
f_schwamborn
i use a MK64FN1M0VLL12 processor on 2 applications, a FRDM-K64f board and a custom application. I noticed that the processor would not boot after longer power failures (> than 20 seconds) and only a manual reset makes the processor boot again. Shorter periods do not lead to this behaviour.
The ethernet phy does not seem to fail because it provides a stable 50MHz clock output.
Does anyone have an idea, what may cause this problem ?
Fabian
Tags (2)
adriancano
Hi Fabian,
This issue was already discussed, check this thread:
FRDM-K64F booting issue when powered from USB port
Hope this information can help you.
Adrian Sanchez Cano
Technical Support Engineer
adriancano
Hi Fabian,
Adrian Sanchez Cano
f_schwamborn
thank you for your help. I had the same issue with a capacitor on the NMI pin.
Fabian
