2 questions global var (W/PE), CW quits
Discussion created by Guest on Sep 26, 2007
Latest reply on Sep 27, 2007 by CrasyCat
1) using processor expert on a  HCS12 in 4.6, where should i make a global variable so that main, as well as ISRs can see it?  just to be sure, i want to edit "main" in "User Modules" under the "processor expert tab", correct?
2) does anyone else have the problem where CW quits any time you try and open a file, or save as. seems like its any time that mini windows explorer is open, the one with that drop down menu at the top, "open" and "cancel" buttons on the bottom right.
IBM T40 running: Windows XP SP2, on a 1.6ghz Pentium M, 2gb RAM, ATI9000 graphics
Thanks, Bret.
