Scheduling question for MQX
Question asked by Dongsheng Wang on Dec 2, 2014
Latest reply on Dec 2, 2014 by soledad
I tested the following project in FRDM-k64F.
/* MQX task IDs */
#define KTEST1_TASK          1U
#define CANADA_TASK          2U
#define WORLD_TASK           3U
/* MQX task stack sizes */
#define KTEST1_TASK_STACK_SIZE 1024
const TASK_TEMPLATE_STRUCT MQX_template_list[] =
  /* Task: Ktest1 */
    /* Task number                    */  KTEST1_TASK,
    /* Entry point                    */  (TASK_FPTR)Ktest1_task,
    /* Stack size                     */  KTEST1_TASK_STACK_SIZE,
    /* Task priority                  */  8U,
    /* Task name                      */  "ktest1",
    /* Task attributes                */  (MQX_AUTO_START_TASK),
    /* Task parameter                 */  (uint32_t)(0),
    /* Task time slice                */  (uint32_t)(0)
  /* Task: CANADA */
    /* Task number                    */  CANADA_TASK,
    /* Entry point                    */  (TASK_FPTR)Canada_task,
    /* Task name                      */  "Canada",
    /* Task attributes                */  (MQX_TIME_SLICE_TASK),
    /* Task time slice                */  (uint32_t)(100)
  /* Task: WORLD */
    /* Task number                    */  WORLD_TASK,
    /* Entry point                    */  (TASK_FPTR)World_task,
    /* Task name                      */  "World",
  TASK_TEMPLATE_LIST_END
void Ktest1_task(uint32_t task_init_data)
  _task_id ktest1child;
  ktest1child = _task_create(0, CANADA_TASK, 0);
  if(ktest1child==MQX_NULL_TASK_ID)
  printf("\nFailed to create task Canada\n");
  else
  printf("\nSuccess to create task Canada\n");
  ktest1child = _task_create(0, WORLD_TASK, 0);
  printf("\nfailed to create task World\n");
  else
  printf("\nsuccess to create task World\n");
  _task_block();
void Canada_task(uint32_t task_init_data)
  int counter = 0;
  printf("\nHellow Canada\n");
  while(1) {
    counter++;
    /* Write your code here ... */
void World_task(uint32_t task_init_data)
  int counter = 0;
  printf("\nHellow World\n");
  while(1) {
    counter++;
When I run this project, the status of task ktest1 is blocked. the status of _mqx_init_task is terminating. the status of task Canada is always active, and the status of task World is always ready, even I set the Canada_task as MQX_TIME_SLICE_TASK. It still looks like FIFO Scheduling.
