Current problem  MC9S08QE16 in Stop3.
Question asked by Braulio_Cespedes on Dec 2, 2014
Hello Everyone.
Recently I was assigned a project. But to achieve that project, I need to make the MC9S08QE16 go below to 4uA with a extern RTC.
Currently I was able to achieve 25-22~uA with RTC and 8-7.5~uA without RTC.
I had read a lot in the forum but I cannot make it go below.
I will attach some picture and the code.
Processor Expert Components:
Processor Expert CPU config:
RTC config:
  1. LVD module is disable in Stop mode.
  2. All unused I/O pins were set as Output and default value 0;
  3. ADC module is disable.
Thanks for advance.
Original Attachment has been moved to: Source-Code.txt.zip
