Optimized memxxx freescale version (user space libraries)
vasanthsri
Hi All,
I guess there is some custom library(libxxx) which provides optimized APIs (memcpy, memset etc..) provided by freescale for all/few embedded processor ? If yes, could someone help/redirect me to the link or relevant documents ?
Thanks.
alexander_yakov
These mentioned functions may be optimized with using SPE (Signal Processing Engine) instructions. Yes, we offer "libcfsl" library which contains 7 functions that use SPE instructions: memcmp memcpy memmove memset strcmp strcpy strlen
http://cache.freescale.com/files/netcomm/software/libraries/libcfsl_e500.zip
However, I see P4040 and e500mc mentioned in tags of this topic - please note SPE support is removed in e500mc core.
alexander_yakov
vasanthsri
Hi Alex,
Can you please check this link
link
I can see there is some library named libppc and last change log is against Freescale. Is this library changes not under GPL?
Please let me know your view.
vasanthsri
I assume there is no such/similar optimized/customized code available for P4 series processor esp. e500mc .Thanks. if available, please kindly let us know.
vasanthsri
Thanks Alex for quick prompt.
Yes,you're right I requested for P4040 processor. I had an assumption that this "libfsl" memxxx functions are -not- designed/intended only with SPE instruction and also optimal for all ppc based modern embedded processor design.
If you have any reference link for memxx procedure intended for e500mc based processor's, kindly let me know.
Thanks.
