Shaojun Wang
Application example to call caam driver
Discussion created by Shaojun Wang Employee on Nov 27, 2014
This is the sample code to call caam driver from user space, on L4.1.0 BSP.
In u-boot, add "caam" in command line.
In kernel menuconfig, select
<*>   User-space interface for hash algorithms
<*>   User-space interface for symmetric key cipher algorithms
To verify if application have called caam, run “cat /proc/interrupts | grep caam”, if caam interrupt counts is increased, caam driver is called.
Original Attachment has been moved to: Makefile.txt.zip
Original Attachment has been moved to: test_caam_crypto.c.txt.zip
