I.MX6: Android register access tool
Question asked by sureshrao Employee on Nov 26, 2014
Hi, All,
The attached tool can be used to access register from android terminal window.
How to Build:
Create directory 'regaccess'  under 'external' directory in the android root directory, copy the attached files and build android images.  The built system image will now include 'regaccess' utility to read/write registers in android.
Syntax:
     $ regaccess <register> [val]
To read IOMUX register located at 0x20e0000
$ regaccess 0x20e0000
To write to 0x0 to register 0x20e0000
$ regaccess 0x20e00000 0x0
Hope this helps in debugging issues from android.
Suresh
Original Attachment has been moved to: Android.mk.zip
Original Attachment has been moved to: regaccess.c.zip
