mediaserver crashed
Question asked by fei wang on Nov 24, 2014
Hi, I am using custom hardware based in IMX6q and Android4.2.2 is ported on it.
I play media files in the secondary screen, while playing on the main screen, frequent operation will cause mediaserver to crash.
I tried to incrase the size of fbmem and gpumem,but the test results has no changed.
Is there anyting  i can try to fix this problem.
The log like:
I/ActivityManager( 2610): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.freescale.cactusplayer/.VideoMenu} from pid 3876
D/DisplayManager( 2610): getDisplayInfo: displayId=0, info=DisplayInfo{"内置屏幕", app 800 x 600, real 800 x 600, largest app 800 x 775, smallest app 600 x 575, 56.000004 fps, rotation 0, density 160, 213.0 x 213.0 dpi, layerStack 0, type BUILT_IN, address null, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/Cactus ( 7328): VideoPlayer: onStart
D/Cactus ( 7328): VideoPlayer: onResume
D/TouchD ( 2352): Entering CheckVIDinlsusb()
D/TouchD ( 2352): Command busybox lsusb | grep 0eef output to /dev/null failed.
D/TouchD ( 2352): Entering CheckIniDevPID
D/Cactus ( 7328): surfaceCreated
I/OMXPlayer( 2275): Loading content: sharedfd://32:0:83869253:0
I/OMXPlayer( 2275): LEVEL: 1 FUNCTION: MediaTypeInspect LINE: 1656
I/OMXPlayer( 2275): Can't inspect media content type by subfix.
I/OMXPlayer( 2275): LEVEL: 1 FUNCTION: prepare LINE: 422
I/OMXPlayer( 2275): failed to open file: /data/system/audio_pass_through_pref.
D/Cactus ( 7328): surfaceChanged: 1280 x 720
I/OMXPlayer( 2275): Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so
I/OMXPlayer( 2275): Cannot load library: load_library(linker.cpp:745): library "lib_aacplusd_wrap_arm12_elinux_android.so" not found
W/audio_hw_primary( 2275): out_set_parametersbingking88 routing=1024, ret 4, out 1074101848
I/vpu-lib ( 2275): Product Info: i.MX6Q/D/S
I/ActivityManager( 2610): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.jd.etms.selfd.client/.MainActivity} from pid 3876
E/BufferQueue( 2272): [com.freescale.cactusplayer/com.freescale.cactusplayer.VideoPlayer] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
I/OMXPlayer( 2275): VideoRender role: video_render.surface
I/OMXPlayer( 2275): nPreCacheSize = 603375
I/vpu-lib ( 2275): <gpu> alloc handle: 0x4f1dbd30, paddr: 0x7817d000, vaddr: 0x46da4000
I/vpu-lib ( 2275): <gpu> alloc handle: 0x4e5ebfe0, paddr: 0x7cdf6000, vaddr: 0x4ba1d000
D/dalvikvm( 2610): GC_FOR_ALLOC freed 864K, 29% free 8082K/11248K, paused 66ms, total 66ms
D/Cactus ( 7328): VideoPlayer: onPause
E/MediaPlayer( 7328): pause called in state 4
E/MediaPlayer( 7328): error (-38, 0)
I/vpu-lib ( 2275): <gpu> alloc handle: 0x413ad1a0, paddr: 0x1de00000, vaddr: 0x50713000
W/InputMethodManagerService( 2610): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@40e3d388 (uid=1000 pid=2820)
I/vpu-lib ( 2275): <gpu> alloc handle: 0x4cd1d2c0, paddr: 0x11000000, vaddr: 0x50866000
I/vpu-lib ( 2275): <gpu> alloc handle: 0x4c5edc60, paddr: 0x790d6000, vaddr: 0x47cfd000
I/vpu-lib ( 2275): bitstreamMode 1, chromaInterleave 1, mapType 0, tiled2LinearEnable 0
I/vpu-lib ( 2275): <gpu> free handle: 0x4f1dbd30, paddr: 0x7817d000, vaddr: 0x46da4000
I/vpu-lib ( 2275): <gpu> free handle: 0x4e5ebfe0, paddr: 0x7cdf6000, vaddr: 0x4ba1d000
E/vpu-lib ( 2275): _IOFreePhyMem: gpu allocator failed to free buffer 0x413ad1a0
I/OMXPlayer( 2275): LEVEL: 1 FUNCTION: FreeOutputBuffer LINE: 3771
I/OMXPlayer( 2275): FreeOutputBuffer: free vpu memory failure : ret=0x1
E/v_gralloc( 2275): Failed to register buffer hnd=0x4f1dbd50
W/GraphicBufferMapper( 2275): registerBuffer(0x4f1dbd50) failed -22 (Invalid argument)
E/GraphicBuffer( 2275): unflatten: registerBuffer failed: Invalid argument (-22)
E/v_gralloc( 2275): Failed to register buffer hnd=0x4e48f8e0
W/GraphicBufferMapper( 2275): registerBuffer(0x4e48f8e0) failed -22 (Invalid argument)
E/v_gralloc( 2275): Failed to register buffer hnd=0x4e48f9b8
W/GraphicBufferMapper( 2275): registerBuffer(0x4e48f9b8) failed -22 (Invalid argument)
E/v_gralloc( 2275): Failed to register buffer hnd=0x4e48faa8
W/GraphicBufferMapper( 2275): registerBuffer(0x4e48faa8) failed -22 (Invalid argument)
E/v_gralloc( 2275): Failed to register buffer hnd=0x4e48fb98
W/GraphicBufferMapper( 2275): registerBuffer(0x4e48fb98) failed -22 (Invalid argument)
E/v_gralloc( 2275): Failed to register buffer hnd=0x4e48fc88
W/GraphicBufferMapper( 2275): registerBuffer(0x4e48fc88) failed -22 (Invalid argument)
E/v_gralloc( 2275): Failed to register buffer hnd=0x40fca650
W/GraphicBufferMapper( 2275): registerBuffer(0x40fca650) failed -22 (Invalid argument)
E/v_gralloc( 2275): Failed to register buffer hnd=0x40fca7c8
W/GraphicBufferMapper( 2275): registerBuffer(0x40fca7c8) failed -22 (Invalid argument)
I/OMXPlayer( 2275): Set Player Speed to 1.000000.
I/OMXPlayer( 2275): Setting same speed scale.
D/DisplayManager(16132): getDisplayInfo: displayId=0, info=DisplayInfo{"内置屏幕", app 800 x 600, real 800 x 600, largest app 800 x 775, smallest app 600 x 575, 56.000004 fps, rotation 0, density 160, 213.0 x 213.0 dpi, layerStack 0, type BUILT_IN, address null, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/Microlog.PropertyConfiguration(16132): Configure using the simple style (aka classic style)
I/Microlog.PropertyConfiguration(16132): Root level: DEBUG
I/Microlog.PropertyConfiguration(16132): Adding appender com.google.code.microlog4android.appender.LogCatAppender
I/Microlog.PropertyConfiguration(16132): Adding appender com.google.code.microlog4android.appender.FileAppender
I/vpu-lib ( 2275): <gpu> alloc handle: 0x41062570, paddr: 0x10e00000, vaddr: 0x50d66000
D/dalvikvm(16132): GC_FOR_ALLOC freed 165K, 13% free 2563K/2916K, paused 26ms, total 26ms
I/dalvikvm-heap(16132): Grow heap (frag case) to 4.514MB for 1920016-byte allocation
D/Cactus ( 7328): surfaceDestroyed
I/OMXPlayer( 2275): xxxxStop Player.xxxx
D/dalvikvm(16132): GC_FOR_ALLOC freed 47K, 9% free 4391K/4792K, paused 26ms, total 26ms
D/dalvikvm(16132): GC_CONCURRENT freed <1K, 9% free 4391K/4792K, paused 4ms+3ms, total 34ms
I/vpu-lib ( 2275): <gpu> free handle: 0x4c5edc60, paddr: 0x790d6000, vaddr: 0x47cfd000
I/vpu-lib ( 2275): <gpu> free handle: 0x4cd1d2c0, paddr: 0x11000000, vaddr: 0x50866000
I/vpu-lib ( 2275): <gpu> free handle: 0x41062570, paddr: 0x10e00000, vaddr: 0x50d66000
I/OMXPlayer( 2275): LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2529
I/OMXPlayer( 2275): DeInitFilterComponent: free memory failure !!!
F/libc ( 2275): Fatal signal 11 (SIGSEGV) at 0x4f4c8ba0 (code=1), thread 10257 (Binder_B)
D/DisplayManager( 3876): getDisplayInfo: displayId=0, info=DisplayInfo{"内置屏幕", app 800 x 600, real 800 x 600, largest app 800 x 775, smallest app 600 x 575, 56.000004 fps, rotation 0, density 160, 213.0 x 213.0 dpi, layerStack 0, type BUILT_IN, address null, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/dalvikvm(16132): GC_FOR_ALLOC freed <1K, 9% free 4391K/4792K, paused 18ms, total 18ms
I/dalvikvm-heap(16132): Grow heap (frag case) to 5.282MB for 852816-byte allocation
I/DEBUG ( 2271): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 2271): Build fingerprint: 'unknown'
I/DEBUG ( 2271): Revision: '405522'
I/DEBUG ( 2271): pid: 2275, tid: 10257, name: Binder_B >>> /system/bin/mediaserver <<<
I/DEBUG ( 2271): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 4f4c8ba0
D/dalvikvm(16132): GC_FOR_ALLOC freed 0K, 8% free 5224K/5628K, paused 30ms, total 30ms
D/dalvikvm(16132): GC_CONCURRENT freed <1K, 8% free 5226K/5628K, paused 3ms+4ms, total 28ms
I/Microlog(16132): 2015-11-21 12:02:58,727 MainActivity [INFO] - MainActivity is create
I/DEBUG ( 2271): r0 4f4c8b98 r1 00000001 r2 00000004 r3 00000001
I/DEBUG ( 2271): r4 4f4c8b98 r5 00000000 r6 00000017 r7 52474347
I/DEBUG ( 2271): r8 4f308dcc r9 000003f5 sl 40188228 fp 00000000
I/DEBUG ( 2271): ip 40bc5f28 sp 4f308bd8 lr 40b667b7 pc 40b655fc cpsr 80000030
I/DEBUG ( 2271): d0 000000003e8ccccd d1 7e37e43c00000021
I/DEBUG ( 2271): d2 3fa925d9ef847320 d3 3f1150f93b6d8d46
I/DEBUG ( 2271): d4 bf97637ba8594245 d5 0000002800000000
I/DEBUG ( 2271): d6 4204000041300000 d7 3f4d1c903debc8c1
I/DEBUG ( 2271): d8 0000000000000000 d9 0000000000000000
I/DEBUG ( 2271): d10 0000000000000000 d11 0000000000000000
I/DEBUG ( 2271): d12 0000000000000000 d13 0000000000000000
I/DEBUG ( 2271): d14 0000000000000000 d15 0000000000000000
I/DEBUG ( 2271): d16 0000000000000001 d17 0000000000000000
I/DEBUG ( 2271): d18 4000000000000000 d19 bf66ba9e379c1526
I/DEBUG ( 2271): d20 3fc550de29c9d47c d21 3e66376972bea4d0
I/DEBUG ( 2271): d22 3fe9a3920542ca12 d23 0000000000000000
I/DEBUG ( 2271): d24 0000000000000000 d25 3f7599cd461969de
I/DEBUG ( 2271): d26 3f40624dd2f1a9fc d27 0000000000000000
I/DEBUG ( 2271): d28 0000000000000000 d29 0000000000000000
I/DEBUG ( 2271): d30 0000000000000000 d31 0000000000000000
I/DEBUG ( 2271): scr 68000010
I/DEBUG ( 2271):
I/DEBUG ( 2271): backtrace:
I/DEBUG ( 2271): #00 pc 000265fc /system/lib/libGAL.so
I/DEBUG ( 2271): #01 pc 000277b3 /system/lib/libGAL.so (gcoSURF_Unlock+18)
I/DEBUG ( 2271): #02 pc 00002469 /system/lib/hw/gralloc_viv.imx6.so (gc_gralloc_unregister_buffer(gralloc_module_t const*, native_handle const*)+128)
I/DEBUG ( 2271): #03 pc 000015d7 /system/lib/hw/gralloc.imx6.so (gralloc_unregister_buffer(gralloc_module_t const*, native_handle const*)+16)
I/DEBUG ( 2271): #04 pc 000074ad /system/lib/libui.so (android::GraphicBufferMapper::unregisterBuffer(native_handle const*)+36)
I/DEBUG ( 2271): #05 pc 000066b5 /system/lib/libui.so (android::GraphicBuffer::free_handle()+16)
I/DEBUG ( 2271): #06 pc 000067cb /system/lib/libui.so (android::GraphicBuffer::~GraphicBuffer()+18)
I/DEBUG ( 2271): #07 pc 000067e9 /system/lib/libui.so (android::GraphicBuffer::~GraphicBuffer()+4)
I/DEBUG ( 2271): #08 pc 0001d4c5 /system/lib/libgui.so
I/DEBUG ( 2271): #09 pc 000247d7 /system/lib/libgui.so (android::sp<android::GraphicBuffer>::~sp()+10)
I/DEBUG ( 2271): #10 pc 00024831 /system/lib/libgui.so (android::SurfaceTextureClient::~SurfaceTextureClient()+80)
I/DEBUG ( 2271): #11 pc 0002485d /system/lib/libgui.so (android::SurfaceTextureClient::~SurfaceTextureClient()+4)
I/DEBUG ( 2271): #12 pc 0000efe1 /system/lib/libutils.so (android::RefBase::decStrong(void const*) const+40)
I/DEBUG ( 2271): #13 pc 00005dcf /system/lib/lib_omx_player_arm11_elinux.so (android::OMXPlayer::~OMXPlayer()+134)
I/DEBUG ( 2271): #14 pc 00005e15 /system/lib/lib_omx_player_arm11_elinux.so (android::OMXPlayer::~OMXPlayer()+4)
I/DEBUG ( 2271): #15 pc 0000efe1 /system/lib/libutils.so (android::RefBase::decStrong(void const*) const+40)
I/DEBUG ( 2271): #16 pc 0002be3f /system/lib/libmediaplayerservice.so (android::sp<android::AHandler>::~sp()+10)
I/DEBUG ( 2271): #17 pc 0002d2fb /system/lib/libmediaplayerservice.so (android::MediaPlayerService::Client::disconnect()+122)
I/DEBUG ( 2271): #18 pc 0004a90b /system/lib/libmedia.so (android::BnMediaPlayer::onTransact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+114)
I/DEBUG ( 2271): #19 pc 00014361 /system/lib/libbinder.so (android::BBinder::transact(unsigned int, android::Parcel const&, android::Parcel*, unsigned int)+60)
I/DEBUG ( 2271): #20 pc 00016f5d /system/lib/libbinder.so (android::IPCThreadState::executeCommand(int)+516)
I/DEBUG ( 2271): #21 pc 00017381 /system/lib/libbinder.so (android::IPCThreadState::joinThreadPool(bool)+184)
I/DEBUG ( 2271): #22 pc 0001b15d /system/lib/libbinder.so
I/DEBUG ( 2271): #23 pc 00011267 /system/lib/libutils.so (android::Thread::_threadLoop(void*)+114)
I/DEBUG ( 2271): #24 pc 00010dcd /system/lib/libutils.so
I/DEBUG ( 2271): #25 pc 0000e3f8 /system/lib/libc.so (__thread_entry+72)
I/DEBUG ( 2271): #26 pc 0000dae4 /system/lib/libc.so (pthread_create+160)
I/DEBUG ( 2271):
I/DEBUG ( 2271): stack:
I/DEBUG ( 2271): 4f308b98 00000004
I/DEBUG ( 2271): 4f308b9c 00000000
I/DEBUG ( 2271): 4f308ba0 4f308bcc
I/DEBUG ( 2271): 4f308ba4 0000772e
I/DEBUG ( 2271): 4f308ba8 00000000
I/DEBUG ( 2271): 4f308bac 401fa6e7 /system/lib/libbinder.so (android::ProcessState::self()+110)
I/DEBUG ( 2271): 4f308bb0 c0000000
I/DEBUG ( 2271): 4f308bb4 00000000
I/DEBUG ( 2271): 4f308bb8 4f308c10
I/DEBUG ( 2271): 4f308bbc 00000000
I/DEBUG ( 2271): 4f308bc0 00000001
I/DEBUG ( 2271): 4f308bc4 4014e833 /system/lib/libc.so (dlfree+34)
